Message 11 of 39
Re: BT Superfast Fibre capped at 34,998Kbps
Out of interest what is the name of the package showing in My BT you may have been put on the essential package in error
Message 12 of 39
Not with a 35M cap.
Message 13 of 39
Message 14 of 39
Hi @craigski, I agree that your connection appears to be banded. The moderation team will be happy to help if you send over your details by replying to the Private message that I'll send you in a moment.
Message 15 of 39
the one main fact the stats don't show is your internet connection time - not system uptime
Message 16 of 39
Thanks All for the useful info/posts, I report back once issue is looked into by @NeilO
Message 17 of 39
I checked yesterday, line had been up for 4 days. I checked this morning and it had been up since exactly 4:00am, possibly due to a forced re-sync?
https://community.plus.net/t5/Library/FTTC-DLM-What-it-is-How-it-works/ba-p/1322799
"Any changes made by DLM are executed between 3am-5am, this is to lower the impact this has on the user. Changes made by DLM will force a resynchronisation (quick disconnection between your BT Openreach Modem and Cabinet)."
However its still stuck at 34,998
Message 18 of 39
After a couple of PMs with the mods (thank you!) , they arranged a scheduled profile reset, which happened this morning. Now syncing at ~45Mbs.
Message 19 of 39
Message 20 of 39
speed back up but if your connection is dropping as often as your posted then you need to keep a check as constant resets will result in the drop in speed and banding again
you may need engineer visit
