Message 1 of 6
BT TV Install engineer visit
Do I really have to pay £20 for an engineer to visit and set up my BT TV?
I am computer savvy and already have a ethernet hub sat next to my 4K tv, with the hub hardwired to my BT router, so can I opt out of the engineers visit?
5 REPLIES 5
Moderator
Moderator
Message 2 of 6
Re: BT TV Install engineer visit
Hi @steviegal,
Thanks for posting. If it's a UHD order then there's no way round the engineer visit. It's in place to make sure everything is set up correctly at the end user premises.
Cheers
David
Message 3 of 6
Thanks DavidM, seems a waste of £20 as all they will do is connect an ethernet cable from the BT box to my hub.
Recognised Expert
Message 4 of 6
I would keep close eye on it as you make get a call like I did to say they cancelled install and want to delay
Message 5 of 6
I had BT TV for around 6m before moving to the UHD service a week ago.
Both times they just sent me the box and I self installed. No problems at all and no engineer visit required.
Recognised Expert
Message 6 of 6
also online they give you different install times to what BTTV would offer you if you phone up - online you can get from 7am but not if you phone them
