Message 11 of 119
Re: BT TV Purchases
Thank you - all fixed.
Very much appreciated
Message 12 of 119
Re: BT TV Purchases
This has happened to me too. How can it be fixed?
Message 13 of 119
Re: BT TV Purchases
How do I fix this problem on my own account?
Message 14 of 119
Re: BT TV Purchases
Hi There, I didn’t fix it, a moderator picked up the problem then a BT TV specialist went onto the system I presume and made some changes to the requirement tree.
Brian
Message 15 of 119
Re: BT TV Purchases
Hi @Cfursland
Sorry for the inconvenience, a fix has now been provided.
Can you try again and let me know if now working?
Message 16 of 119
Re: BT TV Purchases
It’s still not working:(
Message 17 of 119
Re: BT TV Purchases
@Cfursland
Ok don't worry, I did predict you'd say that, I have already asked our supplier to check their end too, this is something we don't have visibility of.
As soon as it is also fixed their end I will re-post with an update, I have already created a fault on my side for tracking purposes so I will be back in touch.
Message 18 of 119
Re: BT TV Purchases
Do you need my log in details or anything?
Thank you 🙏
Message 19 of 119
Re: BT TV Purchases
No we have everything we need 🙂
Message 20 of 119
Re: BT TV Purchases
Hi @Cfursland
Sorry for the delay in getting back to you, your issue should be fixed now if you could kindly confirm.
