Message 1 of 29
BT TV R8000
I have an R8000 which netgear have told me should work with bt tv no problem and when i said it didnt work they were confused to say the least if anyone knows how to set up this router without the hh3 hh4 hh5 i would be more than happy to know.
Tags (3)
28 REPLIES 28
Message 2 of 29
Re: BT TV R8000
You need a modem as a starter as the R8000 doesnt have one.
You can buy an Huawei HG612 or ECI focus on ebay which one is best depends on th hardware in the cabinet
Once you have a modem the setting for BT Tv is in advanced WAN
Message 3 of 29
Re: BT TV R8000
Thats the problem i have it all set up it just wont work
Message 4 of 29
Re: BT TV R8000
As I said you need a modem. Do you have one? Without it the R8000 can't connect
Message 5 of 29
Re: BT TV R8000
yeah i do have a modem it is set up it just wont work i can get on the internet ect but bt tv wont work igmp enabled
Message 6 of 29
Re: BT TV R8000
Update yourfirmware
Then go into advanced settings set up wan
Select british telecom igmp flag yes
Message 7 of 29
Re: BT TV R8000
done that still not working
Message 8 of 29
Re: BT TV R8000
It works on my r7000
How is the youview box connected to the router?
Message 9 of 29
Re: BT TV R8000
powerline 1gbps
Message 10 of 29
Re: BT TV R8000
Update yourfirmware
Going back to this point is that in the modem?
