Message 1 of 4
BT TV freeview
Is there any hope future BT TV boxes will use freesat or IPTV base all freeview channels without using terrestrial freeview?
When I first moved here in August I had pretty much all the freeview channels available. Recently I've lost most of the wanted freeview channels and some are pixelated. I've retuned,bought a new aerial even tried an old freeview box. The same still happens.
Freeview is just so unreliable and ropey at times and just think there's got to be a better way! If it doesn't improve, then will have to get Virgin Media as I'm missing the basics of television.
3 REPLIES 3
Recognised Expert
Message 2 of 4
Re: BT TV freeview
I've found that since the switch over to digital only that Freeview has been pretty rock solid.
Could it be you're tuning to a weak transmitter?
Recognised Expert
Message 3 of 4
Re: BT TV freeview
You can already get all the main channels over the internet, both live and on catch up, using iPlayer etc.
Message 4 of 4
Re: BT TV freeview
Agh yes I discovered you can watch BBC channels live through Iplayer.
I've completely lost Sky News,Pick TV,Spike,Viva and several others.
