Lezah85
Message 1 of 2
BT TV via YouView+ Box - recordings
Does anyone know if one can change/extend the record settings via the YouView+ box.  A few of our recordings lately have ended before the end of the programme has been reached.
With a previous BT vision box we could either set the record times manually or add a fixed amount of time to the record settings.
Thanks for any help or suggestions.
Kind regards
Hazel
1 REPLY 1
TimCurtis
Guru
Message 2 of 2
Re: BT TV via YouView+ Box - recordings
Unfortunately not.
Youview use the start & stop timings sent by the broadcaster at the time of the broadcast & unlike many other boxes don't allow for any manual adjustment. It's too complicated is the argument.
The fault lies with the broadcaster not sending out the correct timings.
