hugo9
Newbie
Message 1 of 7
BT Total Broadband CD
Hi all,
I have just received my BT Broadband and managed to install the wireless and are now connected to the Internet.
My problem is: I can't play the CD that came with the package, I get this message,
(Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39)
My computer is a HP Pavilion dv6 Notebook PC
Thank you in advance for your help.
Hugo.
6 REPLIES 6
Distinguished Guru
Message 2 of 7
Re: BT Total Broadband CD
Hi Hugo and welcome,
Treat it as a blessing in disguise, you don't need to install the CD to get online, as you've discovered.
-+-No longer a forum member-+-
jjgraphics
Recognised Expert
Message 3 of 7
Best thing to do with the CD is to use it as a coaster or bird scarer!
Vb
Newbie
Message 4 of 7
Problem loading CD Broadband Installation
I can't get the CD to load at all.  I called the help desk and they are sending me another CD but I don't hold out much hope for that either.  I can get online ok so what's the CD for??  Should I worry about it?  What am I missing?
It stops and goes round and round forever after I enter my phone no.???
I keep giving up.
Anyone else experience this problem?
Thanks for listening...hmmm a coaster huh...
Message 5 of 7
Re: Problem loading CD Broadband Installation
Just forget about the CD, its not needed.
Vb
Newbie
Message 6 of 7
Thanks Keith 🙂
Message 7 of 7
it is reported as causing more trouble then it cures as you will see if you use the search feature
