the Home hub 3 wired connection is an issue .. i have been fobbed off since Tuesday 19/6 ... my broadband crashed and then came back up at an amazing slow speed i.e 0.3mbps and ever since the speed has been between that and 0.8mbps - Bt have admitted to me that it is a problem and a hardware one!!! but were very vague around it ..... anyway its nearly sunday now and still operating at a speed of about 0.7mbps... Grrrrrrrrrrrrrrr
regards VT
that link was about problems with vdsl (infinity) not adsl which from the figures you posted I assume you are on adsl and not vdsl. if vdsl then you have a real problem with such low speed.
If you are on adsl and in order for the forum members to help please can you post the adsl stats from your router may need to 'show detail' to get all stats (if hub enter 192.168.1.254 in your browser and navigate to adsl or use a-z, if netgear enter 192.168.0.1) and run btspeedtester (MAC users may have problems) bt speedtester and post the results .
are you connected directly via a filter to the NTE5 master or test socket or to somewhere else? Is the master the only phone socket in your home?
Have you tried the quiet line test? - dial 17070 option 2 - should hear nothing - best done with a corded phone. if cordless phone you may hear a 'dull hum' which is normal
Someone may then be able to offer help/assistance/suggestions to your problem
with your attenuation I would expect a connection speed of about 1/1.2mb as you are about 5km from the exchange. what about the master/test socket and quiet lin test?
Hi villatone,
I have around the same line length as you. Are you currently connected to your master socket or test socket?
At your line length I was getting around 0.8-1.2mb. But with a noise margin of 6dB not 10dB
I notice your connection time is 7hrs. Have you manually reset or restarted it? The hub should be connected and kept on 24/7 to prevent any problems.
I would get your noise margin reset to 6dB but after a 3+day stable connection
Someone Solved Your Question? Please let other members know by clicking on ’Mark as Accepted Solution’ | Try a Search See if someone in the community had the same problem and how they got it resolved. |
SORRY I AM A LITTLE BIT SLOW ... BEAR WITH ME ... HERE THE SPEED TEST RESULTS !!!
Your connection speed is the speed that your Home Hub communicates with the Telephone Exchange. This is usually the maximum speed your line can support for the broadband you're on.
The estimated connection speed is set when you ordered broadband with BT. This was based on various checks including the distance of your home to the Telephone Exchange and the quality of your telephone line.
connected to master, no line or noise problems....
Bt also checked the status of the line remotely and could see that there was a very slow speed going from the exchange to the Hub ..... if you read that posted link very carefully it refers to wired connections to the bt home hub 3 which is exactly what i have .... so i am quite sceptical that this is all linked in somehow or just plain coincidence ...... i appreciate the support and help you suggesting .... but nothing as changed here ,... other than broadband going down then back up and all of a sudden slow speeds .......... nothing touched........
are you able to connect it to the test socket then repost adsl statistics to see if there is anything noticable?
cheers,
James
