Message 1 of 2
BT WIFI APP
Hi,
I've installed the application on my phone but there's no way of un-logging it from my WIFI, is that correct or do I just uninstall the Application?
1 REPLY 1
Distinguished Guru
Distinguished Guru
Message 2 of 2
Re: BT WIFI APP
Launch the app, press the phone's Menu button > Settings > Connection Settings > uncheck Login Automatically. Or just turn the phone's wifi on when you need it, which also saves the battery.
