johnjohn1
Message 2 of 3
BT WIFI login on windows mobile?
I just read that the BT wifi windows mobile app has been withdrawn. Real pain in the A** because the connection login keeps getting reset!!!!!
Is ther any other way to get the windows phone mobile to remember the login credentials for bt wifi fon?
2 REPLIES 2
johnjohn1
Message 1 of 3
bt wifi app for windows 8/10?
1) Where is the windows 8/10 version of the wifi app?
http://www.btwifi.com/help/login-with-bt/free-app.jsp
2) When signing into bt wifi via the mobile windows phone browser it tells you to download the app from the store but it is not there when it directs you to the store!
3) I have an older windows mobile 8 where I installed the bt wifi app so i know it used to exist. What is happening now?
DavidM
Moderator
Moderator
Message 3 of 3
Re: BT WIFI login on windows mobile?
Hi @johnjohn1 and welcome.
I'm sorry you're unhappy at the App being withdrawn. Your best bet would be to contact the App tech guys on 080002233 22 who might be able to help with his. You'll get further information at BT Wi-fi app.
Cheers
David
