Hello, I get this issue described in title. It only persists in chromium based browsers (chrome, opera, latter was to test).
In chrome, for example I can open bing.com, but 99% other wbesites throw me the error message.
Although I am able to proceed to the page beyond the error via a link, the page is rendered as plain text, I presume because all the images and scripts are 'non secure', from what I've read.
Whats the best solution for this? In the past I tried exporting a websites certificate and then importing into chrome and IIRC, that let me onto that website but this is per website, thus a tedious process and does not always work.
An observation is that even if a hyperlink and what it links to is http, Opera seems to redirect all HTTP to HTTPS. I can't see an option to turn this needless over provisional/ hinderance of a feature off. I appreciate that companies want to look out for those uneducated on the matters but atleast give people an option......
BTW I access BT via BT-Fon. I do not have a landline, I piggyback off a neighbors available hotspot and this is sufficient. Firefox works fine but is teribbly optimized on this machine.
Regarding BT-FOn Proxy, I don't necesserily trust it. i.e. after looking for a solution for another seperate problem; I wasn't able to turn off safe search OFF in google search, in the end I accepted this as undefeatable because its documented that this is inherant part of BT wifi hotspots.
Solved! Go to Solution.
that is a problem with BTWIFI/FON that anyone with a BT sign in can use it and it should not be used for and private/personal information it is mainly intended for surfing when out and about
Please don't post if you have no intention to help. That is a half baked solution. It isn't re assuring that portable surfing isn't secure, either. In all very dissapointed in this response.
Here's hoping someone else who is technically inclined in this area can elaborate further.
sorry but that is the problem BTWIFI is not secure and should not be used for private or personal information. of course you can ignore the warning and go online shopping or banking but you leave your data open to misuse up to you if you want to risk it
Hi @shorterxp,
You can find out more information here - How secure are BT Wi-fi hotspots?
PaddyB
To be clear, I CAN access HTTPS sites on firefox. Just not chrome.
Then use firefox
As stated in post #1 firefox is incompatible with my PC.
It doesn't state that at all.
