Sterling
Message 1 of 6
BT Whole Home (Wholehome) WIFI >>> meaning of "Signal Strength"
The Whole Home App shows a signal strength
The BT Whole Home App shows a signal strength for the wireless-only discs. My readings vary over time but one indicates -77 and the other -74 as I write.
Do these readings have a particular relevance, say in terms of dBW, or are they just relative numbers?
Are my readings good or poor?
5 REPLIES 5
Dan-O
BT Devices Expert
BT Devices Expert
Message 2 of 6
Re: BT Whole Home (Wholehome) WIFI >>> meaning of "Signal Strength"
Hi,
Are you referring to signal strength under disc details or device information?
Sterling
Message 3 of 6
Hello
I am referring to the Disk Details in the App.
Regards, Sterling
Dan-O
BT Devices Expert
BT Devices Expert
Message 4 of 6
Sorry - I didn't see the rest of your message the first time.
The readings refer to the signal in dBm.
Anything between -50 and -80 is ideal - this number influences whether the disc shows as "excellent", "good" or "poor".
Sterling
Message 5 of 6
Thank you, Dan-O, I appreciate your clear response.
I now understand the numbers are dBm.
I seem through early experimentation to achieve numbers in the -70 to -79 dBm region unless I have perfect line of sight between two transceivers in which case I can get figures of around about -55 dBm.
Now that I understand the boundaries (and with the addition of a power point in the hall), I may be able to contrive line of sight communications between transceivers.
Regards, Sterling
Graham888
Message 6 of 6
Hi Dan O,
Noting that your reply applies only to the discs - does the same range apply to the numbers shown in the App for connected devices?
Kind regards,
Graham
