Message 1 of 3
BT Whole Home WiFi - compatibility with Hybrid Connect
I have 4 of the original BT Whole Home WiFi discs (not the mini ones). As such, the WiFi from my BT Home Hub is switched off and my home network is based entirely on wifi from the Whole Home discs.
I am considering upgrading to Halo 3+, which includes Complete WiFi. My question is: Will I still be able to use my original BT Whole Home WiFi discs - i.e. are they compatible with the latest BT home hub and Complete WiFi discs? Will all the discs form part of one network?
Thanks in advance.
2 REPLIES 2
Message 2 of 3
Re: BT Whole Home WiFi - compatibility with Hybrid Connect
The white BT Whole Home wifi discs and the black Complete wifi discs are for two different systems and as such they will not work together.
Message 3 of 3
Thanks - I thought that was the case. I could sell the Whole Home discs I guess, but would certainly need more than one of the new black ones
