Hi,
Wondering if anyone can help. I bought a 4 disc BT WholeHome set to work with my Virgin Media router. (Am not BT customer).
My BT WholeHome Wifi network works fine but I cannot get the App on my iPhone to see the system anymore. It kept coming up with various error messages and saying cannot "Connect to your Wifi network" (which was working fine).
In frustration I tried deleting the App and re-downloading. It says Connect To Your Router then Turn On Disc and then connect to WiFI as if it is a new system. When you do Next on all the options it says "Unable to detect new disc".
Can anyone offer any solutions as it is incredibly frustating..
Thanks in advance
@thediceman Can you try resetting the discs to factory default to see if that helps?
First, make sure the discs are switched on
I too have the same problem - connected to internet fine but recently (maybe due to an apple software update?) bt whole home app cant connect to wife/local network - any ideas welcome!
