Message 11 of 16
Re: BT Wi-Fi sign in problem
Yes, it gave the same message about "Create a BT ID.
Message 12 of 16
If it was an openworld address did you try it with the btinternet.com suffix?
Message 13 of 16
Yes, Keith Beddoe suggested that in the initial response.  It got the result "Unknown problem. There is an unexpected error causing a problem" Have re-tried after closing App - same result!
Just tried again now, same result
Message 14 of 16
I think you will need to call the BTWifi help line 0800.022.3322 to see if they can help.
Message 15 of 16
Many thanks. I will try that in the morning - hopefully they will answer faster than 0800 800 150 who I have tried 3 times and given up after 20 plus minutes in the queue!!!
Message 16 of 16
Thank you - I got an instant answer on the phone on that number for BT WiFi!!!! It was a known problem. I had to change my email address on MyBT for btopenworld to btinternet even though they are interchangable when using them for email.
