Message 1 of 3
BT WiFi Hotspot
I have a BT Home Hotspot kit with a master near the hub and two extensions around the house.  One of them is recognised on my iPad and requests the password to join, however it will not join and I note that the Data light does not light up.
I have tried resetting the hotspot without success.  Any clues please?
2 REPLIES 2
Distinguished Guru
Message 2 of 3
Re: BT WiFi Hotspot
Did you get them as a two-pack, plus an extra one?  If so, I'd guess the one that's not working is the extra one.
All powerline adaptors need pairing with the master.  When you buy a set, they will have been paired in the factory, but if you buy an extra one, you have to go through a process to associate the new one with the master.  This will be set out in the instruction manual.
Message 3 of 3
Re: BT WiFi Hotspot
Thank you. Most helpful
