Message 1 of 18
BT WiFi & android 6.0
Since android on my Motorola nexus upgraded to android 6.0 the BT WiFi app has stopped connecting to hotspots and I have to logon via the btwifi landing page on my browser. Any ideas?
17 REPLIES 17
Message 2 of 18
Re: BT WiFi & android 6.0
Have you tried uninstalling the app, re-starting your phone then re-instlling the app.
Message 3 of 18
Yes a couple of times as well as trying hotspots at more than one location.
Message 4 of 18
Still not working
Message 5 of 18
Still not working
Recognised Expert
Message 6 of 18
BT need to update the app to work with Marshmallow, they've had plenty of time to do this - I have ended up uninstalling the app as it won't work at all (using Nexus 6 with Marshmallow) and no clue as when they will update it - will just have to keep checking the play store
Message 7 of 18
Just to add to this. I recently changed my phone to a nexus6p which also runs android 6.0. This setup has the same problem in that it does not now work with bt WiFi hotspots. This is annoying. I also reported this to BT but their response was 'there is no problem with the app and the latest version of android'. I will try reporting this again and post any response here.
Message 8 of 18
etx01 - Have you evr reported this as an issue to BT ? I think reporting it is probably the best bet on this. I will report it tomorrow. I did have a phone number to contact BT wifi support direct rather than go through all the call centres - I will try to find the number and post on here. I reported it last weeek and will do so again tomorrow.
good luck
Message 9 of 18
The BTWifi App developers can be contacted here btwifi.support@bt.com
Message 10 of 18
I will give that a try
