Message 1 of 7
BT Wifi Booster
I have BT fast fibre with home hub 4 and my speed is 50Mbps...I live in a ground floor flat at the rear of a block. My car is parked out the front and i need to protect it but need wifi. The signal needs to go through 3 doors with a distance of approx 50metres. Can any Booster help get my signal that far..Please if anyone can help...Thx
6 REPLIES 6
Message 2 of 7
Re: BT Wifi Booster
Message 3 of 7
Re: BT Wifi Booster
Hi...Thx for taking the time to reply. I have looked at the link and the price is reasonable. Are they plug-ins and how will they work please
Message 4 of 7
Re: BT Wifi Booster
You plug one in next to the hub and connect an Ethernet cable between the extender and hub and just plug the other one in a mains socket close to where you want the wifi. There's a diagram if you expand  Product Description on the link
Message 5 of 7
Re: BT Wifi Booster
Thx so much...brilliant!
Message 6 of 7
Re: BT Wifi Booster
@licquorice will this work if the OP is in a self contained flat? My experience shows that consumer units may well prevent this working and I read it the the WiFi section might be plugged in to a communal area of the property
Message 7 of 7
Re: BT Wifi Booster
Must admit I hadn't considered that, I assumed the sockets would all be in the same property fed by one consumer unit. If that is not the case, then no, they probably won't work.
