Message 1 of 6
BT With Fon On New Hub
Upgraded to Infinity 2, It was activated, and the new hub arrived. Its all fine, However the hub is broadcasting the BT FON wifi hotspots. I called BT and they told me that since I am not opted it, it should be fine. On my BT, it says that I am not opted it. Thanks.
5 REPLIES 5
Message 2 of 6
Re: BT With Fon On New Hub
that service is activated by default on your new hub you will have to opt out is you do not want the service however please remember if you do opt out you will lose access to BT Wi-Fi when out and about
Message 3 of 6
How do i opt out, as it only says opt in?
I will wait 1-2 days and see.
Distinguished Guru
Message 4 of 6
You may have to wait a lot longer than that.  Other people on this forum have indicated that it can take BT up to 28 days to turn off BT WiFi.
Distinguished Guru
Distinguished Guru
Message 5 of 6
You can check your status and opt out here. Opting out won't improve your service though, just as staying in won't be detrimental. Most of the opposition to being opted in is groundless.
Message 6 of 6
Thanks, Contacted live chat, and it was off by the next day 🙂
