darrylgreen187
Message 1 of 3
BT Xenon 1500 - caller display ?
I have a new BT Xenon 1500 cordless phone. The caller display on this does not seem to work. With my old phone I used to get caller display with one of those little wedge shaped Caller reminder display devices, that would show the number calling, or 'International number' or 'Witheld number' etc. I looked in the manual and it says
Can anyone help ?
Quis custodiet ipsos custodes?
2 REPLIES 2
Distinguished Guru
Message 2 of 3
Re: BT Xenon 1500 - caller display ?
Hi
Just to ensure that caller display is still active on your line just try dialling *#234# and listen to what announcement you get.
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
darrylgreen187
Message 3 of 3
cheers.
