Newbie
Message 1 of 2
BT YouView Remote for SlingPlayer
I have a Sling box at home but have yet to find a working remote control for the new BT YouView+ box. Having tried a few different options the best I've managed to find is the Humax DTR-T1000. Everything pretty much works correctly except the cursor buttons. Whenever I press left or right it seems to send a double signal and as if I've pressed the button twice. This means that it's impossible for me to get to the On Demand and MyView option in the menu as it always skips over them. To add to the strangeness of this it's only on the YouView main menu menu. If you are on the Guide option and press up to go into the sub menu it then moves by one when clicking left or right.
Has anyone got a Slingbox Solo and a YouView box and managed to get it working?
1 REPLY 1
Newbie
Message 2 of 2
Re: BT YouView Remote for SlingPlayer
OK. I chased this up in multiple places and the other forum maanged to fix it. If you have the same issue or just need a remote for a BT YouView+ box on sling then check out the forum post here: BT YouView+ Remote for SlingPlayer
Also, if you don't know how to install a custom remote teh instructions are here: How to add Custom Remotes
