Message 1 of 11
BT YouView box - app showing but not enough band width
Hi guys - We have the Amazon Prime app showing on our set-top box, and have signed into our Prime Account.  All tickety boo, so far?  However, when we try to play anything (this evening fancied watching an episode of "Jack Ryan"), an error message appeared saying we have insufficient bandwidth, and won't play at all.
We have infinity 2, and right now our speed test returrns 66.3mb download and 18.4mb upload - with said Jack Ryan playing via AppleTV.
What's that all about?  Anyone have any ideas?
10 REPLIES 10
Message 2 of 11
Re: BT YouView box - app showing but not enough band width
How is your box connected to the router?
Message 3 of 11
Thanks for responding.  My router and BT TV box are connected directly by ethernet cable.
Message 4 of 11
Just in case unplug and replug either ends of the ethernet cable then restart the set-up box
Message 5 of 11
Thanks, Chris - I've just done that, but need to poop out now for a while, but will test it later.
Message 6 of 11
Too much information Smiley LOL
Message 7 of 11
Aaaaaaawwwwww, and there was I thinking that was going to be a helpful lpost, but worry not; @Cris101's suggestion work.
Thanks everyone.
Message 8 of 11
Presumably this is a error message reported from within the Amazon Prime Video app rather that a Youview generated  one.
Message 9 of 11
Correct - I could brrowse through the content, select a programme, but when I asked it toplay, the error was consistent.
Unplugging, replugging and restarting both router and BT TV box seem oto have sorted it out.
Message 10 of 11
Hi @MiracleMaud,
Thank you for posting back, I'm glad that has worked for you.
Cheers
PaddyB
