darianthomson
Message 1 of 3
BT YouView connected to BT HomeHub 5 via a Netgear Switch
Hi,
I'm thinking of getting BT Entertainment Plus and was wondering does the Youview+ Box's Extra channels work if connected via a Netgear switch? The reason I have the switch is because my HomeHub 5 is 10m away from my XBOX 360 and Bluray player and I'd like to connect the Youview+ Box the same way as they are connected to my network/internet.
Thanks in advance 🙂
Tags (2)
2 REPLIES 2
siteguru
Expert
Message 2 of 3
Re: BT YouView connected to BT HomeHub 5 via a Netgear Switch
As long as the switch routes multicast packets then it should be fine. (The internet channels built in to the YV box - i.e. those NOT using an app - such as BT Sports use multicast. Those channels, like Motors TV, that connect via a (hidden) app will work fine without multicast).
Ian
http://www.siteguru.co.uk/be/ADSL2PlusForDummies.pdf - Having ADSL issues? Then read this PDF
Please don't click the star beside my name - too many stars makes you look like a swot!
darianthomson
Message 3 of 3
Thank you 🙂
I've ordered it now and will let this forum know how I get on.
