craigb123
Message 1 of 2
BT Youview box internet connection with Non BT Modem router
I have BT Infinity and BT TV both connected with a BT Smarthub. The smarthub seems to have loads of issues, I'm waiting for a HH5 but have the following question:
Has anyone used a BT TV Youview box with a non BT modem router? I've seen various routers that are compatable with BT Infinity but some warn that BT TV doesn't work with non BT modem routers.
The router I was thinking of getting is a TP-link Archer VR600, anyone used one of these or similar with BT Infinity and BT TV?
1 REPLY 1
TimCurtis
Recognised Expert
Message 2 of 2
Re: BT Youview box internet connection with Non BT Modem router
Personally I use an Asus DSL-AC68U which works fine with BT Sport etc.
The TP-Link 9980 is reported as working well & is alot cheaper than my Asus.
There's a sticky here: Compatible non-BT routers that has some details of setups for routers known to work. There's also another thread around about this - Routers known to work
