nadbutt
Message 1 of 2
BT Youview box pixelation
I am extremely disappointed with this BT Youview box, i have recently upgraded from just BT infinity and phone line to BT infinity + BT TV + BT Phone line. Since i have got it, i have experienced pixelation with the TV channels, my TV signal seems ok. I have tried retuning channels and am lost, i start work quote early and finish work quite late and by the time i get home the helpdesk is closed. Are there any tips someone can suggest?
Right now it is terrible as i watch More4 ,
I am getting 44 signal
44 signal strength
32 signal quality
But this seems to fluctuate during the day...
1 REPLY 1
Keith_Beddoe
Message 2 of 2
Re: BT Youview box pixelation
What is the signal like if you connect your TV aerial direct to the TV, as most TVs have a signal strength and signal quality information screen?
Is the YouView box connected directly to the input of the YouView box?
You need a signal strength between 70-90% and a signal quality of 100%. If you are not getting that, then you have a fault with your TV aerial installation.
If you are getting a very strong signal reading on the TV, then the signal may be too strong for the YouView box, and you may need an attenuator.
