dwatki
Message 131 of 140
Re: BT and BTSpeedtester on it's **bleep** yet again?
I am using a BT activated line for the Tests that are 'FAILING to complete'.
I mention the Satellite Link because I get better than 8 Mbps DL in Rural France. I would expect better than 3 Mbps DL in the UK. Is this unrealistic for BT ADSL ?
imjolly
Message 132 of 140
just depends on how far you are from the exchnage and the quality of your phone line
DS
Distinguished Guru
Message 133 of 140
Just when I thought things were starting to work
(tested at 01:06)
1. Best Effort Test: -provides background information.
 Download  Speed
 0.01 Mbps
Beta on the blink too:(
Download Speed (Mbps): 0.00
Upload Speed (Mbps): 0.00
Ping Latency(ms): 66.20
-+-No longer a forum member-+-
imjolly
Message 134 of 140
beta worked for me this morning
Aarong
Guru
Message 135 of 140
Yea just gave it a quick go and is working for me as well.
If you want to say thanks for a helpful answer, please click on the Ratings star on the left-hand side If the the reply answers your question then please mark as ’Mark as Accepted Solution
pottyperson
Distinguished Guru
Distinguished Guru
Message 136 of 140
Summat's happened! The original just performed the quickest test I've ever seen and came up with a sensible result:
Alanrf
Message 137 of 140
Just a thought.  Before you got that realsitic result did you -
- turn off all antivirus softwre?
- did did you power cylcle your router?
If not, did you try it like later that as a double check?
_________________________
Alan
pottyperson
Distinguished Guru
Distinguished Guru
Message 138 of 140
Nope, nope and nope. I'm not bothered about my speed right now as I know it's around 17Mbps, as it should be. I was just seeing if BT Speedtester was back on the rails yet. Seems it is. Until the next time at least.
Alanrf
Message 139 of 140
Re: BT and Puppeteers on it's **bleep** yet again?
Fair comment.   Like you I regard the speedtest results as a guide, no more, no less.
The only figures of interest, really, are the IP profiles, .
Realistically, the general speed throughput must vary considerably, over any given period of time.   This can be particularly noticeable around here in the evenings and in school holidays.
Alan
DS
Distinguished Guru
Message 140 of 140
Both are working now, for me anyway, but they still don't give the same result
speedtest 5.81Mbps - though assured rate still fails
beta d/l 6.82Mbps, u/l 0.34Mpbs, ping 74.56
