john46
Message 11 of 140
Re: BT and BTSpeedtester on it's **bleep** yet again?
That looks fine from here 🙂
DS
Distinguished Guru
Message 12 of 140
and another
-+-No longer a forum member-+-
DS
Distinguished Guru
Message 13 of 140
Hmm, I did agree
FAQ
Results Image not loaded
1. Best Effort Test:
Download Speed : 128 Kbps
Your speed test has completed and the results are shown above, however during the test an error occurred while trying to retrieve additional details regarding your service. As a result we are unable to determine if the speed you received during the test is acceptable for your service. Please re-run the test if you require this additional information.
Hub stats still spot on
This may explain my Skype problemSmiley Frustrated
I may have to open that case again:(
DS
Distinguished Guru
Message 14 of 140
edit. Tried the third test, note the banner at the top states Last Test equired - not Required:o
Third test, after changing to speedtest@speedtest_domain, fails with
FAQ
null
The Performance Tester is currently unable to run a speed test for your broadband connection. Please try again shortly, however if this problem persists, raise the issue with your service provider.
imjolly
Message 15 of 140
DS
just tried btspeedtester again and I also am getting a very low download speed - in the red like you.  never had that before suggesting is knackered again
must be btspeedtester as my download speed on newsgroup is normal
robh66
Message 16 of 140
It must be on the blink, because i had a hub 3 software update yesterday and i'm on Infinity and it gave me an 11Meg download speed, but no upload speed, and just now i re - tested it and it gave me 2Meg on the Download and 6.75Meg on Upload.
But Speedtest.net gave me 29Meg on the down and 8.1Meg on the up.
DS
Distinguished Guru
Message 17 of 140
Guess it must be:(
But doesn't explain the images on post 13.....:|
john46
Message 18 of 140
reading low here as well looks like it is really playing up now
imjolly
Message 19 of 140
just ran btspeedtester again and it was ok this time - so inconsistent
DS
Distinguished Guru
Message 20 of 140
Red at this end and the beta is also still all over the place
