Message 1 of 7
BT app not displaying mobile connected to wi fi
If I run the BT app and check my wi fi networksnetwork I can see all devices connected to the Smart Hub 2 and Disc .
Only problem is my mobile phone which is connected to same network is not displayed.
If I log into the hub admin on 192.168.1.254 and look at devices I can see my mobile displayed ok. Any idea why.? Doesn't matter if I am connected to hub or disc.
On the app if I look at offline devices the mobile is displayed but it is clearly online and connected to wi fi.
Any ideas?
6 REPLIES 6
Message 2 of 7
Re: BT app not displaying mobile connected to wi fi
Hi @Emrsw01
Thanks for your post and welcome back!
I assume that when your phone connected to your Wifi network it wasn't automatically picked up and is why it's not showing on the app.  It's a good one for us to feedback though.  The main thing is that the mobile is showing within the Hub manager interface.
Thanks for letting us know.
Cheers,
Robbie
Message 3 of 7
That may be the case although it has showed up on the app ok until recently.
Any resolution?
I have uninstalled the app and reinstalled and checked if from my Android Tablet but results still the same.
Message 4 of 7
Problem resolved.
Went on phone settings and told it to forget wi fi network.
Then scanned again for wi fi.  Entered code and now all works a treat.
Can see phone when connected to disc or hub from the app and hub manager ok.
Message 5 of 7
Check your mobile phones network settings. On newer phones for security reasons they default to use a random Mac address. So your phone will be shown as connected but under a different Mac address which you won't recognise.
Go to mobile phone network settings, then Network details
Privacy (random mac or device Mac)
Message 6 of 7
I'm fairly sure that after 2 years the problem has been resolved.
Message 7 of 7
I just had the same issue and the suggested solution didn't work. So I thought I would update with the solution that worked for me. Sorry if you feel that was a waste of time.
