Message 1 of 19
BT boost engineers.
Long story,but it grinds down to having a much lower sync rate than neighbours immediately around me,example being 10 doors down (stone throwing distance) has a sync of 7616, 25db Downstream attenuation and a 9.5db noise margin compared to my 4288 / 49 / 6.4.
Isp isn`t with BT,althought phone still is,just trying to search for answers as to why being on the same cab (no reason why i shouldn`t be) and the same exchange i have a much lower sync (no extentions,direct into test socket).
Is there a charge for boost engineers? Would one be worth arranging?
18 REPLIES 18
Distinguished Guru
Message 2 of 19
Re: BT boost engineers.
You would have to contact your ISP who would arrange the visit and pass on the charges to you.
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
Message 3 of 19
hi there area variety of reasons for your speed the most obvious is your line attenuation
firrst it is very possible you may not be conected to the same street cab also the route your line takes is obviously longer then that of you neighbours also its condition could be different eg more joints in different cable thickness's there are just a few of the variables if you are by chance on another cab then nothing can be done at all
Message 4 of 19
Hi there
To say your line is obviously a lot longer than your neighbours is over simplifying. Your line may be in a much worse state of repair than your neighbours or your internal wiring may be at fault. Router reported attenuation is not a clear indication of line length. You will see from a fair few posts on this forum that following line repairs or upgrades peoples attenuation can be significantly reduced. Obviously their house has not walked closer to the exchange!
Message 5 of 19
No,their house is still where it was this morning. 😛
No extentions,running via the test socket,tried various combinations of filters/routers so the only conclusion i have is the *problem* if there is one would be outside my property.
Line seems quiet,no hiss so i guess i`d have to risk a charge by requesting a visit?
Recognised Expert
Message 6 of 19
Do you still have the 448 upstream by any chance?
And I dont know whether it would be any use, but I wrote this article, I only usually give it to people on long lines, but its about tidying up their socket, the lower half of it http://goo.gl/ddnG2
Message 7 of 19
Yea,still on 448 upstream here,my exchange (Shorne - NDSHO) is a tiny one,no LLU/WBC.
Read your guide,pretty much have things like that on my master socket already,that`s what puts me down to guessing the issue lies outside.
Recognised Expert
Message 8 of 19
It cannot do any harm, to see what the mods think, before that would you mind posting your ADSL stats by following this direct link; http://192.168.1.254/ and go to A-Z (top right) and then ADSL Status and post everything including Line Attenuation, Noise Margin, Connection Speed, Errors etc...
Message 9 of 19
You could certainly ask the mods this is a link to them http://bt.custhelp.com/app/contact_email/c/4951 they reply normally within 72 hours by email or phone as you are not a Bt broadband user I am not sued they can help o n this occasion but do try
Message 10 of 19
Just got in from work,so here`s all the stats you should need.....remember i`m currently on day 6 of a line retrain.
/usr/sbin/adslctl: ADSL driver and PHY status
Status: ShowtimeRetrain Reason: 0
Channel: INTR, Upstream rate = 448 Kbps, Downstream rate = 4288 Kbps
Link Power State: L0
Mode:                   G.DMT
Channel:                Interleave
Trellis:                OFF
Line Status:            No Defect
Training Status:        Showtime
                Down            Up
SNR (dB):       5.5             21.0
Attn(dB):       50.0            31.5
Pwr(dBm):       19.6            11.9
Max(Kbps):      4736            1024
Rate (Kbps):    4288            448
                        G.dmt framing
K:              135(0)          15
R:              12              16
S:              1               8
😧              16              2
                        ADSL2 framing
MSGc:           1               1
B:              135             15
M:              1               8
T:              1               1
R:              12              16
S:              1.0882          9.0000
L:              1088            128
😧              16              2
                        Counters
SF:             8710169         8710183
SFErr:          357             21
RS:             592291538               74036555
RSCorr:         8844059         151
RSUnCorr:       20691           0
HEC:            96              9
OCD:            30              1
LCD:            0               2
Total Cells:    1497441813              0
Data Cells:     233023178               0
Drop Cells:     0
Bit Errors:     0               0
ES:             35              0
SES:            7               0
UAS:            85              0
AS:             148075
INP:            0.70            1.00
PER:            1.90            1.96
delay:          4.35            4.50
OR:             29.40           28.44
Bitswap:        0               0
Total time = 1 days 17 hours 10 min 50 sec
SF  = 8710169
CRC = 357
LOS = 16
LOF = 0
ES  = 35
Latest 1 day time = 17 hours 10 min 50 sec
SF  = 3638176
CRC = 333
LOS = 16
LOF = 0
ES  = 14
Latest 15 minutes time = 10 min 50 sec
SF  = 38232
CRC = 0
LOS = 0
LOF = 0
ES  = 0
Previous 15 minutes time = 15 min 0 sec
SF  = 52923
CRC = 0
LOS = 0
LOF = 0
ES  = 0
Previous 1 day time = 24 hours 0 sec
SF  = 5071993
CRC = 24
LOS = 0
LOF = 0
ES  = 21
15 minutes interval [-30 min to -15 min] time = 15 min 0 sec
SF  = 52982
CRC = 0
LOS = 0
LOF = 0
ES  = 0
15 minutes interval [-45 min to -30 min] time = 15 min 0 sec
SF  = 52923
CRC = 1
LOS = 0
LOF = 0
ES  = 1
15 minutes interval [-60 min to -45 min] time = 15 min 0 sec
SF  = 52923
CRC = 0
LOS = 0
LOF = 0
ES  = 0
Showtime Drop Reason:   0
Last Retrain Reason:    0
