Message 1 of 1
BT box connection to Apps (Amazon Prime, Netflix) keeps dropping out
Have had a BT box for several years. Suddenly keeps loosing connection to Wifi meaning can’t use Amazon Prime, Netflix etc. Might connect  and stream for few minutes but then drops out. Have disconnected BT box, reset, re-started router, run speed test (looks fine)etc. But problem continues.
