Message 1 of 7
BT broadband using ADSLMax with slow upload (capped 448kbs) when ADSL2+ is available
Good evening,
Hopefully someone can help me with an issue I have with a slow upload speed.
Recently due to increased costs I switched my Broadband from Sky (copper) after being with them for many years with no issues on speed or reliability.
Since moving across we are experiencing upload speeds of less than half of Sky which is resulting in a number of issues.  The BT broadband is G.992.1 Annex A (448 / 6122 which appears to have the upload capped and using adslmax when adsl2 is available which was used when on SKY.
Is there anything that can be done to either remove the 448kps cap or switch to the adsl2+ to improve the very slow upload.
I have included some details below which should be of use.
Many thanks for any advice or assistance anyone can offer.
1. Product name:
BT Home Hub
2. Serial number:
+068340+NQ64402353
3. Firmware version:
Software version 4.7.5.1.83.8.130.1.32 (Type A) Last updated 24/02/17
4. Board version:
BT Hub 4A
5. ADSL uptime:
1 days, 11:51:55
6. Bandwidth:
448 / 6112
7. Data sent/received:
2.0 GB / 50.2 GB
8. Broadband username:
bthomehub@btbroadband.com
9. BT Wi-fi:
No
10. 2.4 GHz Wireless network/SSID:
BTHub4-9C6X2.4D
11. 2.4 GHz Wireless connections:
Enabled (802.11 b/g/n (up to 144 Mb/s))
12. 2.4 GHz Wireless security:
WPA and WPA2
13. 2.4 GHz Wireless channel:
Automatic (Smart Wireless)
14. 5 GHz Wireless network/SSID:
BTHub4-9C6X5D
15. 5 GHz Wireless connections:
Enabled (802.11 a/n (up to 144 Mb/s))
16. 5 GHz Wireless security:
WPA2
17. 5 GHz Wireless channel:
18. Firewall:
Default
19. MAC Address:
20. VPI/VCI:
0 / 38
21. Modulation:
G.992.1 Annex A
22. Latency type:
Interleaved
23. Software variant:
24. Boot loader:
BT BROADBAND AVAILABILITY CHECKER
Telephone Number  on Exchange NEWTON-LE-WILLOWS is served by Cabinet 31
Featured Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Handback Threshold(Mbps)
WBC FTTC Availability Date
WBC SOGEA Availability Date
Left in Jumper
High
Low
High
Low
VDSL Range A (Clean)
80
59
20
19
51.5
Waiting list
VDSL Range B (Impacted)
73.7
46.9
20
15
39.8
Waiting list
Featured Products
Downstream Range(Mbps)
WBC FTTP Availability Date
FTTP on Demand
330
30
Available
ADSL Products
Availability Date
Left in Jumper
WBC ADSL 2+
Up to 3
2.5 to 6.5
Available
WBC ADSL 2+ Annex M
Up to 3
Up to 0.5
2.5 to 6.5
Available
ADSL Max
Up to 3
2 to 5.5
Available
WBC Fixed Rate
2
Available
Fixed Rate
2
Available
Other Offerings
Availability Date
VDSL Multicast
Available
ADSL Multicast
Available
Premise environment
Status
Bridge Tap
U
VRI
N
NTEFaceplate
N
Last Test Date
24-05-2018
6 REPLIES 6
Message 2 of 7
Re: BT broadband using ADSLMax with slow upload (capped 448kbs) when ADSL2+ is available
The forum mods should be able to help you get upgraded to adsl2  and I have asked then to help  they will post contact link here
Message 3 of 7
Thank you. Much appreciated and hopefully some light at the end of the tunnel.
Message 4 of 7
as you can see from the checker results your cabinet is fibre enabled but there is a waiting list for conenctions
Moderator
Moderator
Message 5 of 7
Hi @Berty Welcome to the forum and thanks for posting about your upload speed.
We will be happy to help you with this if you send us your details. You can contact us by clicking on my user name and selecting contact the mods.
John
Moderator
Moderator
Message 6 of 7
Hi @Berty,
Thank you for sending in your details and for taking my call today. I've placed an order to have the upload speed cap removed. The order is due to complete on Tuesday. You should start to notice an improvement from Wednesday onwards.
If you notice any issue with your connection following that change, please get back to me.
PaddyB
Message 7 of 7
Hi Paddy,
Thank you for getting back so quickly and it was great being able to talk to someone knowledgeable.
Not only did you find a solution, the work to remove the cap has already been done.
As a result we are seeing uploads around double before and less wifi registration fails. Great result and I will watch over the the next few days to see if it remains stable.
Thank you again for a first class service resolving an issue we have had for a couple of months.
Berty.
