Since the latest update, the BT folder on my computer (windows 10) doesn't sync with the web version. There is no way of forcing a sync. My broadband is working . I can log in to my BT cloud on the web but the files on this don't match the files shown on my computer.
How do I make them sync?
Solved! Go to Solution.
Hi @gvw30,
What do you see when you look at the BT Cloud dashboard on your computer (instructions to access it here): http://bt.custhelp.com/app/answers/detail/a_id/56970/~/getting-started-with-the-new-bt-cloud
Does it say 'All in sync' or give any sort of error message?
It says All files in Sync. But they arn't.
Hmm - it's an odd one. My advise would be to uninstall and reinstall (if you haven't already), and if it's still playing up to call the BT Cloud helpdesk or email btcloud.support@bt.com.
Ah . That has worked. Thanks for your help
