Guru
Guru
Message 1 of 6
BT.com website header and menu bar formatting error.
Hi all,
This is just to raise awareness (if not solved by the morning) that the BT.com template header and menu bar formatting has gone wrong from around 00:14ish on 16/01/14. It may be a that a script or html style sheet have been altered slightly.
On looking at the debug console it looks like the server which contains the header.css stylesheet is not responding (error code 404 [not found]).  The header html style sheet address is https://img01.bt.co.uk/s/assets/271113/css/header.css
Hopefully it just someone doing some site maintenance or updates.
Cheers,
James
jac_95 | BT.com Help Site | BT Service Status
Someone Solved Your Question?
Please let other members know by clicking on ’Mark as Accepted Solution’
Try a Search
See if someone in the community had the same problem and how they got it resolved.
5 REPLIES 5
Guru
Guru
Message 2 of 6
Re: BT.com website header and menu bar formatting error.
Update: the style sheet is fine now.
Had a slight feeling that it might have been just an update or maintenance to the site template.
James
Try a Search
Guru
Guru
Message 3 of 6
Is it me or is something weird happening to the menu bar on the BT.com website today?
The menu bar keeps disappearing for a few mins then comes back, then disappears again.
James
Try a Search
Message 4 of 6
Seems fine here.
Message 5 of 6
not had any problems today - currently using chrome
Guru
Guru
Message 6 of 6
Thanks Keith and imjolly
Was just about to say that the menu had stopped disappearing, though it has now disappeared again. I have also checked with IE and still the same results as Chrome.
Strange
Cheers,
James
Try a Search
