Message 1 of 4
BT email set up on Android Samsung TAB A
I have a new Samsung TAB A using Android  I'm trying to add my BT email account but keep getting error message "UNABLE TO VERIFY ACCOUNT"  I can log in via the BT site No Problem so I know my user I'd and password are correct.
3 REPLIES 3
Message 2 of 4
Re: BT email set up on Android Samsung TAB A
Are you setting the account up manually or letting the wizard do it, what settings are you using? The correct settings are here and should be entered manually.
Message 3 of 4
I was trying to use "Other" but it appears to work when I use "Excange"  is this ok?
Message 4 of 4
I'm surprised you have got it to work by selecting Exchange, but if it does, ok.
