Cobblers_3
Message 1 of 4
BT engineer no show
As title suggest, supposed to come today between 1-6 but no show. After searching this it appears a regular occurrence. My question is, I've had bt here before, I've got my hub, can I just set up myself and it should all be activated? After spending an hour on the phone and bt chat and getting nowhere in close to cancelling!
3 REPLIES 3
imjolly
Message 2 of 4
Re: BT engineer no show
You can try connecting your hub and see if you get connected - activation is often at midnight
are you getting adsl or infinity?
Cobblers_3
Message 3 of 4
Was going to try in the morning as its a bit late now! Do you think they will still activate it then?
imjolly
Message 4 of 4
if you were getting an engineer visit probably not.
with self install which many are nowadays then it would be possible that activation may be at midnight
