Message 1 of 2
BT fibre to TV
1.  TV will now be Ethernet fed from a wifi router, will i leave the TV setting as wired?  2. Will the wifi PC upstairs, which works OK, project to the TV with just this set up?
1 REPLY 1
Message 2 of 2
Re: BT fibre to TV
As long as all devices are connected via the router they will be on the same network and it won't matter how they are connected. Leave the TV setting as wired as that is its dirrct connection to the network
