Hey guys, I am moving to my new appartment in a few weeks but wont have internet until July 12th.
I am having friends over and want to share my internet with them. I have bt at my main house but not at my flat.
Can only 1 person at a time use the BT Fon account?
If so how can i get around that? Can i logg into the internet using wifi and then use tethering on my phone?
Any help would be greatly apreciated. ❤️
Solved! Go to Solution.
You will need a wifi hotspot in range of the flat, and to know the wireless key unless it's an open network to which you have access, like BT Fon. If the mobile signal is strong enough you should be able to tether a phone to a computer; you can also set up a phone as a wireless hotspot, though it would be far less powerful than a broadband router.
What I was trying to ask was:
If i do have a BT Fon signal, which i know the area does.
Can me and my friends logg onto all of our devices in this one property using the same account?
For example 1 friend loggs on bt fon using my acc using laptop and same for the other friend?
If it is only for 1 person where does it say this?
There's nothing to stop you sharing your log-in details, though some might think it unwise. I don't know if it's technically possible for more than one device to log in to the same hotspot at the same time using the same account. Even if it is, the results would be poor; bandwidth is only 512Kbps, and performance even for one connection at a time is notoriously flaky.
The bottom line is that BT Fon is only intended for casual, light use.
@pottyperson wrote:There's nothing to stop you sharing your log-in details, though some might think it unwise. I don't know if it's technically possible for more than one device to log in to the same hotspot at the same time using the same account. Even if it is, the results would be poor; bandwidth is only 512Kbps, and performance even for one connection at a time is notoriously flaky.
Just to add slightly, there are indications that BTFon may well now be faster than 512Kbps (unless the host requires it). Indeed when I was away in Wales, the FON speed on my device seemed to be much faster than that.
I'm beginning to wonder if it's now a percentage of the total BB speed now, may be a mod could find out for sure?
(plus if a premium hotspot is the same)
The question is still really unanswered. The speed doesnt matter at all to me, its only for fb and spotify.
I was just trying to find out if we can all use bt fon using my account.
I was just trying to find out if we can all use bt fon using my account. 🙂
in theory you all can use your one primary BT account to sign in to BTFON - just means that eveyone will know your password. If everyone logs in at once then as BTFON is normally only 512kb then you will find things very slow
