Recognised Expert
Message 11 of 14
Re: BT home Hub 5 swapped for asus-dsl-ac68u - requesting optimum settings for Infinity 2 for router
Only your own line matters. Diff users will be diff distances from cab & therefore have varying speeds. Having a common router is irrelevant. It's just a device to make & measure the connection.
___________________________________________________________________________
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings star on left hand side
Message 12 of 14
please find settings , log and current speed test , previous speeds and BT broadband availiability
  • Administration - DSL Setting
  • System Log - DSL Log
  • current speedtest.net on asus
  • DSL Line Status from Home Hub  5
  • broadband availability checker
Recognised Expert
Message 13 of 14
The DLM system has put you on a banded profile in response to past errors on your line. Your sync speed is being held at the top of one of BT's Banded Profile bands, altho' you now have no significant errors.
The DSL uptime is only 4 mins. Are you keeping discon'ing it, perhaps to swap between the 2 routers? Perhaps that's why. Leave it alone & it'll recover on its own in time.
Message 14 of 14
thank you everyone for your imput
i will leave the router alone and see how it goes
