Keith_Beddoe
Message 11 of 15
Re: BT home hub 3 reconnecting or not?
@j-whitney wrote:
So you home hub isnt actualy dropping connection its just reasking for authentication? how would using ethernet help this?
Its the wireless that is dropping, then reconnecting. If you look here Disconnections
there is an explanation at the bottom.
j-whitney
Message 12 of 15
Ahh I see, but wouldn't the wireless light flash when this is happening rather than the broadband light?
___________________________
Keith_Beddoe
Message 13 of 15
I don`t think it works the same, try turning smart wireless off, and see if that helps.
j-whitney
Message 14 of 15
okay will do, but as long as it is not the connection dropping that's fine :L
thanks
Keith_Beddoe
Message 15 of 15
thanks
No, you would see that on the ADSL statistics.
