Message 11 of 27
Re: BT home hub and broadband issues please help!!
not yet I am going to try them one by one so as not to mess everything up at once.
cheers
steve
Message 12 of 27
also can you try and connect via an ethernet cable if that works with no problem then it will confirm wireless problems
Message 13 of 27
Spoiler
well
well suprise suprise .
recieved my new home hub 3 on tuesday and connected it up tuesday night, connection was fine but kept dropping out on my newish laptop . connected my old laptop up and the connection was fine and stable.
however this morning i got a text from my wife saying the lights had gone out on the home hub, apart from the orange power light which kept flashing and then going blue and then flashing orange again.
this is the third home hib that this has happened too now !!!
now I have no internet connection again
this is beyond a joke, i am on to my 3rd home hub in the 2 weeks i have had broadban connected and i think ive had barely 5 days use in 2 weeks which i find unnaceptable.
I have contacted bt via email but had no reply.
I am loathe to spend another hour on the phone to a call centre.
what can i do ???
Message 14 of 27
Hi I suggest you contact the forum mods they should be able to get your problem sorted for you this is a link to them
http://bt.custhelp.com/app/contact_email/c/4951
they normally reply by email or phone directly to you within 72 hours
They are a UK based BT specialist team who have a good record at getting problems solved
Message 15 of 27
to get 2 new hubs broken in a few days is unlucky but 3!!!!!!!!!!!!!!!!!!!!!Smiley Mad
Message 16 of 27
i would say almost unheard of
Message 17 of 27
Well ive managed to reset this router by turning it off and then back on again. All lights came on for. About ten minutes and then the wireless and broadband lifts have gone out .
The power light is going from blue to Orange and flashing now?
Message 18 of 27
as previously suggested you need to contact the forum mods at the link above
Message 19 of 27
hi i have done as you said in your post but as yet had no reply.
i have been onto the call centre again and it got raised to a level 2 job as it had happend 3 times now.
they are sending me another home hub and rest assured its not going to happen again or so they say.
here is my first speed test resut anyway as somehow this router that has been playing up for the past 3 hours has come back on?????
 Download speedachieved during the test was - 615 Kbps
 For your connection, the acceptable range of speeds is 400-1000 Kbps.
 Additional Information:
 Your DSL Connection Rate :768 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
 IP Profile for your line is - 676 Kbps
Message 20 of 27
the mods are your best option now you have contacted them you would be best advised to avoid the call centre as it can only cause confusion just a matter of waiting for there reply
