Message 21 of 27
Re: BT home hub and broadband issues please help!!
now you hub is working can you post the adsl stats?
Message 22 of 27
Line state:Connected
Connection time:0 days, 01:10:35
Downstream:768 Kbps
Upstream:448 Kbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Modulation:G.992.1 Annex A
Latency type:Interleaved
Noise margin (Down/Up):6.6 dB / 10.0 dB
Line attenuation (Down/Up):71.6 dB / 31.5 dB
Output power (Down/Up):15.2 dBm / 12.6 dBm
FEC Events (Down/Up):1189 / 5
CRC Events (Down/Up):18 / 8
Message 23 of 27
Download speedachieved during the test was - 453 Kbps
 For your connection, the acceptable range of speeds is 400-1000 Kbps.
 Additional Information:
 Your DSL Connection Rate :768 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
 IP Profile for your line is - 676 Kbps
Message 24 of 27
line looks like it is holding just now
as you have only the one socket does it have a test socket as shown in john46 diagram?  if so are you connected to that test socket?
with your attenuation of 71/72 I cannot see a very good connection and probably about 1mb max
Message 25 of 27
I'm on my third hub as well. (see Orange Power Light of Total Death)
It would seem that there has been a batch of dodgy hubs released to the market in the last 4 - 5 weeks. I'm sure that BT are aware of this problem and have checked what batch is effected and withdrawn them.
Aye, right!
Well, you never know....
Message 26 of 27
|I agree with imj a very high attenuation figure unfortunately you will never have a fast connection
Message 27 of 27
Renton the mods can take up to 72 hours to reply they are a small team of UK based BT specialists
