DW
Message 1 of 3
BT hub phone 1010 one way transmission on calls
hi, i've just discovered that when i use my hubphone to make a call out, or receive a call in, that i cannot hear anything, although the person on the other end can hear me.
if i press the green call button before dialling i can hear dial tone, if i then press the digit 5 i can hear the dial tone change (don't know what that is all about) so assume that the hub phone is working until i place the call.
i cannot think of any other way to prove whether the speech paths work as this is the only broadband phone that i have. any ideas? i have just plugged a normal phone into the phone socket on the hub and that is one way transmission as well?
2 REPLIES 2
Community Manager
Community Manager
Message 2 of 3
Re: BT hub phone 1010 one way transmission on calls
Hi DW,
Welcome to the forum.
The dial tone changes when you press "5" to let you know the call will go through your landline number.
Can you try making a call from the Hub Phone through your landline (i.e. by pressing "5" before the number) to see if the problem persists?
Stephanie
Community ModeratorStephanie
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
DW
Message 3 of 3
I switched my computer on yesterday morning and the HUB immediately died and rebooted - the hub phone line has been working OK since even though i rebooted the hub myself previously . i've just spoken to a person from BT and he seems to think the problem might have been on the server
