Message 1 of 31
BT infinity 10 day stabilisation period.
Hello,
My new BT infinity has just started and my current speed is 32mbps I checked my line before purchasing infinity 1 and it says my minimum download speed will be 40 and my max speed will be 52. Will my infinity speed go to 40 after the 10 days of stabilisation period? Or will it stay 32?
30 REPLIES 30
Message 2 of 31
Re: BT infinity 10 day stabilisation period.
if you have a HH5 can you go to hub manager then trobleshooting then helpdesk and post 1-12
can you run btspeedtester and when first test completes then run diagnostic test and post results  must be done with wired connection  btspeedtester
can you enter your phone number and post results  remember to delete number wholesale FTTC check
are you using the test socket with a new filter and hub connected direct to filter without any phone extension cable
Message 3 of 31
The 10 day period is a myth
Message 4 of 31
Ok
Message 5 of 31
Here are the Routers 1-12 Helpdesk
1. Product name:BT Home Hub
2. Serial number:+068543+NQ60533454
3. Firmware version:Software version 4.7.5.1.83.8.204 (Type A) Last updated Unknown
4. Board version:BT Hub 5A
5. DSL uptime:0 days, 04:06:10
6. Data rate:6870 / 34557
7. Maximum data rate:6967 / 34466
8. Noise margin:6.3 / 6.0
9. Line attenuation:38.5 / 26.0
10. Signal attenuation:24.8 / 23.4
11. Data sent/received:340.3 MB / 7.4 GB
12. Broadband username:bthomehub@btbroadband.com
Here is the ADSL Checker:-
Here is the broadband test:-
My Socket has 2 outputs one just for the broadband and one for the phone. This got put in maybe 4 weeks ago by a open reach enginner when I used to be with Sky.
Message 6 of 31
Phone customer services and get engineer visit as your connection speed is well below your estimated speed. It won't get any faster waiting so get engineer
Message 7 of 31
What others say its true however realistically you need to give it some time before they become reactive as their script says you have to wait 10 days
It may be worth checking the order email to see what is the guaranteed speed mentioned
Right now it looks like you have no headroom ao your line may have an issue somewhere
Message 8 of 31
Sorry I would not wait as you will be in same stat 10 days from now so get engineer now and save the wait
Message 9 of 31
It is obvious that you are not getting the speeds you should and they will not improve in ten days time. You do not need to wait 10 days before complaining and requesting an engineer investigates what the problem is.
If Customer Services say that you need to wait ten days just inform them that you are not prepared to wait and if they do not arrange an engineer you will be looking to cancel your contract free of charge.
Message 10 of 31
I will contact BT later and see if I can get one out. When I was with Sky they sent one out and he said their were no problems with the line he tested it 2 times and he fixed a small problem out side and put in a new box. Does this mean it's to do with the line out side of the property and will I be charged if I call one out.
