DrWolfenstein
Message 1 of 10
BT infinity 2 speed has dropped to death...
noticed last night i was having speed issues down to about 8mg and i have checked three times today and its about the same between 8-12mg, i've had Infinty for about 1 and a half months its been fantastic so far with a connection of 78mg so i could never complain. I have run three tests today on the BTW Performance page i'm using a new ASUS laptop running windows 7, can i get a mod to contact me please. I have done tests on the laptop my phone and xbox one they alll show the same thanks for reading...
9 REPLIES 9
ray_dorset
Distinguished Guru
Message 2 of 10
Re: BT infinity 2 speed has dropped to death...
Can you post your helpdesk data from the HH5 please? These are in Troubleshooting/Helpdesk on the web interface at http://192.168.1.254 or http://bthomehub.home or http://bthub.home
Please miss out any data you don't want to post
If not, I'll try again 🙂
imjolly
Message 3 of 10
have you tried using an ethernet cable instead of wireless and see what download speed that shows
DrWolfenstein
Message 4 of 10
1. Product Name: HomeHub52. Serial number: +076284+14360003513. Firmware version: v0.07.03.0814-BT (Type B) Last updated 24/2/20154. Board version: 015. VDSL uptime: 4 days, 04:37:336. Data Rate: 20000 / 623717. Maximum Data Rate: 22042 / 654188. Noise Margin: 6.5 / 6.69. Line Attenuation: 0.0 / 17.310. Signal Attenuation: 0.0 / 0.011. Data sent/received: 1.7 GB / 63.4 GB
DrWolfenstein
Message 5 of 10
 only got a speed of 12mg with the ether net cable plugged in i tried this morning
imjolly
Message 6 of 10
can you run btspeedtester diagnostic test with ethernet cable and post the results please
btspeedtester
ray_dorset
Distinguished Guru
Message 7 of 10
According to your Helpdesk info your data rate is:
Doesn't look like a problem.
DrWolfenstein
Message 8 of 10
looks like a problem when i'm only getting 8-12mg when i was hitting over 50 the otherday?
ray_dorset
Distinguished Guru
Message 9 of 10
Is it all the time or only certain times?
If right now can you run this speedtest please? http://www.thinkbroadband.com/speedtest/speedtest2.html
And post the results
DrWolfenstein
Message 10 of 10
no worries i factory reset the router its been solved thanks anyway people
