Richthemilkman
Message 1 of 11
BT infinity 2 upgrade - no speed change
Good Evening,
I recently upgraded to BT infinity 2 from BT infinity 1 after receiving an offer to re-sign a contract, the agreement stated that my upload should be 16-20 Mbps and download 52-70 Mbps.
Prior to upgrading my speeds were on average 9.41 and 45.87 respectively.
After the upgrade my speeds were on average 9.46 and 45.96.
My new contract started on 1 Feb 2017 so there's been plenty of time for the 'new' connection to settle.
Have I been had or is there something that can be done to get the connection speeds I was promised?
Thanks.
10 REPLIES 10
licquorice
Message 2 of 11
Re: BT infinity 2 upgrade - no speed change
As you were already below the Infinity1 maximum speed cap of 55M, upgrading to Infinity2 will have no effect.
Webby
Message 3 of 11
A little short sighted @licquorice wiith an estimation of 52-70 there may be an issue somwhere.
OP, are you connected to the master socket, or an extension?
Richthemilkman
Message 4 of 11
Thanks for the replies, I am connected to the master socket.  As for the previous comment, if there is no chance of my connection achieving those speeds why am I being offered an upgrade and estimated speeds of 52-70? Would this be considered acceptable practice for BT?
Cheers.
Webby
Message 5 of 11
Can you remove the faceplate and connect to the test socket?
Once you've done that can you post he connection stats up from the router showing the current connectipn rate, plus the attainable rate?
Richthemilkman
Message 6 of 11
Hi again,
Sorry for the delay.
6. Data rate:9999 / 48942
7. Maximum data rate:21185 / 55776
Webby
Message 7 of 11
If that's in the test socket, you need an engineer.
Richthemilkman
Message 8 of 11
Thanks for the reply Webby, that was in the test plate, so do you have any ideas about what I can say to get the engineer? I sort of dread calling up BT support without a very clear definition of what I need otherwise it seems to take 3 or 4 calls being bounced around repeating the same steps to get to the point where I started.
Thanks again for your help.
Webby
Message 9 of 11
Your connection speed is below the estimated range.
Just to confirm that range, can you put your number into here http://www.dslchecker.bt.com and post up the results.
Richthemilkman
Message 10 of 11
Hi Webby,
