Message 11 of 23
Re: BT infinity hub requires multiple resets daily
As I said, I don't have a home hub 5, I've got home hub 3.
Is this what you need?
1. Product name: BT Home Hub 3.0B
2. Serial number: +058721+114812CXPR
3. Firmware version: V100R001C01B036SP05_L_B. Last updated 19/11/13
4. Board version: VER.D
5. WAN: PPP Connected
6. Data sent/received: 19494844/76231939 B
7. Broadband username: bthomehub@btbroadband.com
8. BT FON: No
9. Wireless network/SSID: BTHub3-WFKR
10. Wireless connections: Enabled (b/g/n, 20M, WPS Enabled)
11. Wireless security: WPA and WPA2
12. Wireless channel: Automatic/1
13. Firewall: Default
Distinguished Guru
Message 12 of 23
Yes, the line stats aren't available from the Homehub 3 unfortunately; they're locked inside the modem.
If not, I'll try again 🙂
Message 13 of 23
The laptop doesn't seem to be able to connect through the router. I've been clicking try again repeatedly, but consistently get "connection failed with error 651"
Distinguished Guru
Message 14 of 23
No, you should remove the router (homehub3) and connect the laptop directly to the white Openreach modem.
Message 15 of 23
Sorry, that is what is I meant. Laptop is connected directly to white modem, but can't get it to work.
Distinguished Guru
Message 16 of 23
Can you check the username and password, please?
Message 17 of 23
OK, laptop is now connected directly to modem.  It seems I had to tick the box labelled "allow all users to use this connection" or something similar.
Speedtest.net is reporting about 4.5 Mbps, rather than the usual ~30 Mbps
I've noticed another user is reporting similar problems in this thread:
https://community.bt.com/t5/BT-Infinity-Speed-Connection/Hub-3-needs-to-be-restarted-every-day-to-re...
Message 18 of 23
After running another speedtest (wednesday, ~8am), the laptop connected directly through the modem is now at a much more usual 37 Mbps.
Distinguished Guru
Message 19 of 23
Looks like your hub is broken.
Also, are you getting slow speeds at peak time?
Message 20 of 23
So how do I go about getting the hub replaced?
I hadn't noticed any speed problems, and a test I've run now (17:37) shows 37 Mbps.  I'll do a few more tests through the evening, but the slow one yesterday might have been a one off glitch.
