Distinguished Guru
Message 21 of 23
Re: BT infinity hub requires multiple resets daily
You could try a factory reset of the hub
http://bt.custhelp.com/app/answers/detail/a_id/11386/~/how-do-i-reset-my-bt-home-hub-to-its-factory-...
If not, I'll try again 🙂
Message 22 of 23
Resetting the hub using the recessed button is what was first suggested in this thread. It didn't help.
Distinguished Guru
Message 23 of 23
There were cases a few months ago where multiple factory resets of the Homehub eventually fixed it - don't ask me why though.
When you've had enough of factory resets, you'll have to ring the helpdesk for a replacement.
