Borse2008
Message 1 of 16
BT infinity installation
Hi guys just ordered BT infinity 2. Basically master socket is next to the front door my current main room where the modem/router is located is two floors above the front door. I don't want to have the router. Next to the front door I want to know what you think my possibilities are.
15 REPLIES 15
Annie_UK
Message 2 of 16
Re: BT infinity installation
They will swap the master socket with your extension so you have the modem & router where you want 🙂
Nige32
Message 3 of 16
Hi
     The OR engineer can change the phone socket upstairs (I am assuming that you have one up there where your modem is attached too) to become the master socket. ( subject to testing the internal wiring off course).
Borse2008
Message 4 of 16
O cool yes that's right.
So the current master socket will just become an extension. Upstairs will be the master socket. Was expecting you guys to say need to feed a 3 cat 5 cable outside then back in.
Borse2008
Message 5 of 16
It's a newly built house so I assume the wiring will be good.
Nige32
Message 6 of 16
Hi
     Yes the current master socket would just become the extension.
 If it makes you happy I can also advise running external grade CAT5e from your hall outside up the wall and then back in to a room off your choice, if you want to make the OR engineers life that much easier   Smiley Very Happy .
 Hope your install goes well and you enjoy the speed that Infinity brings .
Borse2008
Message 7 of 16
Well nige that would make it easier. Is that the easy option? Will he have all Of the equipment at no extra cost ?
Nige32
Message 8 of 16
Hi
    The OR engineer would be happy as he or she would only need to install the VDSL next to the master socket in the hall.
He or she would not run external cable, that would be down to you, as I said in my last post "it would make the OR engineers life easier" I did not mean he would do it,  hence the smiley face.
 Of course if you had the time to install network cable round your house then you could place the HH3 into any room, I think all new builds should have that done anyway in this age off fast Internet.
 Still I hope all goes well for you.
 Sorry if I lead you to believe Bt would do something they will not.
Borse2008
Message 9 of 16
The master socket and extension swap sounds less messy?
Annie_UK
Message 10 of 16
Not messy they replace the fronts of the boxes and swap a few wire inside the box, the wiring between boxes stay the same 🙂
Tags (3)
