Recognised Expert
Message 31 of 39
Re: BT infinity support a nightmare
That rating was proberly because the rest of the post was to the point,the only mistake I made was getting the posters mixed up.
Message 32 of 39
And I have noticed you are running true to form.
EDIT: that is correct ironman.
Distinguished Expert
Message 33 of 39
I was merely explaining why I addressed the answer to gg also.
To say thanks for a helpful answer, please click the white star
Recognised Expert
Message 34 of 39
The point is that whoever asked what is not important,what is important is just trying to answer each question as honestly as possible,without all the pointless in between sarcasum, and btw I could never spell sarcasum correctly.
Message 35 of 39
Guys. I think this conversation has deviated from the OPs question a little....
_______________________________________________________
If I've helped, just click the Star - Every little bit helps 🙂
If you can't fix it with a hammer, you've got an electrical problem.
Message 36 of 39
Hi,
I already got the route some weeks ago but after 4 rescheduled appointment, no engineer ever turned up with the vdsl modem...  Thinking about getting a modem off ebay and setting up myself at this stage.
Distinguished Guru
Message 37 of 39
That won't work, you need some changes at the cabinet and the exchange to enable FTTC. The engineer is supposed to do a managed install which includes a new master socket, if you ever have one turn up.
If not, I'll try again 🙂
Sage
Message 38 of 39
As there is work to be carried out at the cab to enable a VDSL connection there would be no point in buying a VDSL modem from ebay.
Message 39 of 39
Didn't get any reply from the mod.  Got my 4th appointment booked for the 8th of november.  Hope someone turns up this time. Spent 3hrs on the phone with them today, almost 25hours over the last 2 weeks.   Loosing my patience now, thinking about walking into their headquarter next week to make a point on this...
