Newbie
Message 1 of 7
BT infinity under guaranteed speed
I got the BT infinity 3 4 days ago, which should guarantee at least 59, or up to 70ish mbps, However the speed is between 20 to 27 down with around 6 up. The line is connected through a filter into the smart hub, with an ethernet connection to my pc.
EDIT: The person living next door to me gets the full speed from the unlimited infinity 1, but im not even getting that speed with unlimited infinity 2 😞
6 REPLIES 6
Newbie
Message 2 of 7
Re: BT infinity under guaranteed speed
I have used the test socket and it is the same speed
Message 3 of 7
if you have a Homehub 5 can you also post the stats from 1-12 by logging onto the homehub management pages then troubleshooting > helpdesk. http://bthomehub.home/
The stats for the Home Hub 6 can be found on the Information page from http://192.168.1.254 then Advanced Settings -> Technical Log.
Can you post back the results of this checker editing out your phone number
http://www.dslchecker.bt.com
Can you use this speed tester then carry out the further diagnostics and post back a screen shot of all the results including your IP profile for up and down.
This test must be done with a wired connection.
http://speedtest.btwholesale.com
Newbie
Message 4 of 7
Screen Shot 2017-08-05 at 23.26.21.pngScreen Shot 2017-08-05 at 23.26.47.pngScreen Shot 2017-08-05 at 23.30.47.png
Newbie
Message 5 of 7
if i need to get an engineer or somthing i will wait the full 10 days and contact BT.
Message 6 of 7
Youi need an engineer now the 10 day time scale is a myth with infinity
Sage
Message 7 of 7
@john46We know it's a myth but customer care still make people wait the full 10 days.
